how do i rip this sound out of a movie divx.avi all my tools wont let me do it thanx
Paste from the King John's Shortscuts
Vdub
There may be many reasons to save out the audio from an AVI movie, you may wish to work on it for use later. You may have a low powered machine that makes it difficult to convert while part of the AVI.
It is not possible to convert from one format to another unless you have the supporting codec installed.
This saves out the audio "As is"
File > Open Video file
File > File information > Can you see the audio type ? If unknown, you have a missing codec.
Check for junk frames
Audio > direct stream copy
SAVE WAV
This converts the audio to an uncompressed WAV
File > Open
Audio > Full Processing mode
Audio > Compression > No compression (PCM)
Audio > Conversion > 44.1Khz (No other changes)
SAVE WAV
Hope that help's !
Virtual Dub say's No audio decompressor to decompress source audio
By s_joy09 in forum Newbie / General discussionsReplies: 10Last Post: 25th Dec 2011, 15:03 -
How do I rip a DVD to a multi-Audio or a DUAL-Audio AVI?
By KneeRow in forum DVD RippingReplies: 8Last Post: 23rd Jan 2010, 14:40 -
how to rip an audio off the net, when the audio is blocked/protected?
By Remyisme in forum Newbie / General discussionsReplies: 2Last Post: 12th Oct 2008, 11:14 -
No Video In Virtual Dub, Just Audio
By AllenM in forum EditingReplies: 11Last Post: 3rd Oct 2008, 14:35 -
db PowerAmp Music Converter
By mccoady in forum ComputerReplies: 7Last Post: 29th Aug 2008, 14:58
