System used : Athlon TBird 1,33 GHz, 256 MB Ram, GForce 2 GTS/32 MB Video Card, Pioneer DVD Rom, WindowsXP Professional.
Viewing problem : DVD player doesn´t playback (I use Zoom Player)
Ripping problem : DVDx says DVD might not be unlocked.
Seems to me as if both problems have the same source, but HOW do I unlock my DVD or drive ?
This is just after installing WinXP, with Win2k it worked. The DVD I tried works well in a standalone player.
Any hints are welcome !
I'm using XP as well with no problems. I seem to remember reading something about locked drives. Like I told someone else just recently, try using a different player and a different ripper, at least this will let you know if the problem is isolated to these applications, if not solving the problem then at least letting you know that the problem is on the OS/hardware level rather then the application level.
Hope this helps,
Prospero
Converting IFO file DVDs to M4v for Iphone viewing
By anotherhappyday1 in forum Video ConversionReplies: 1Last Post: 22nd Feb 2012, 14:41 -
Does anyone run into this problem while ripping your DVDs into HD?
By pwangdel in forum Newbie / General discussionsReplies: 7Last Post: 11th Sep 2007, 21:26 -
new to ripping dvds
By lm932 in forum Newbie / General discussionsReplies: 5Last Post: 28th Aug 2007, 09:37 -
Ripping DVDs to MPEG2 ?
By DigitalSounds in forum Newbie / General discussionsReplies: 11Last Post: 24th Aug 2007, 23:05 -
viewing DVDs from other regions?
By Bansaw in forum Newbie / General discussionsReplies: 3Last Post: 9th Jul 2007, 06:03
