Hi:
How can I change the DMA settings for my Hard Discs and CDR/DVD room in Windows 2000?
I have PC's in my work with Windows 98 and it is easy to change the settings within the "device manager" for each device. However, in W2K the settings do not have the DMA option. Is there any way I can change the DMA options.
Just befor you ask me, yes! I do have administrative rights in W2K.
Thanks for you help with this matter
THX
8)
Rey
In device manager find the ide controller which your dvd/cdrom are attached to. In its advanced settings it will have the opion "DMA if available."
Can you enable DMA for an external DVD burner?
By Erasmus in forum DVD & Blu-ray WritersReplies: 9Last Post: 6th Sep 2009, 11:10 -
Reading UDF CD/DVD with w2k?
By Des in forum ComputerReplies: 8Last Post: 12th Jan 2009, 15:40 -
Weird Doings in PIO - DMA-ville
By Seeker47 in forum ComputerReplies: 13Last Post: 28th Nov 2008, 14:15 -
False "Unsafe Unmount of USB" error msg. from W2K
By Seeker47 in forum ComputerReplies: 5Last Post: 7th Dec 2007, 15:57 -
NTLDR is missing on Clean Install (attempt) of W2K Pro
By louv68 in forum ComputerReplies: 84Last Post: 29th May 2007, 19:41
