I have an avi that comes with a separate .sub file.What prog do i need to open the sub?Can it be opened with windows media player?
Thanks![]()
Windows Media Player doesn't like the *.sub files. I believe you can open *.sub files with MicroDVD Player available here:
http://www.tiasoft.de/
Windows Media Player has another format that it likes for subtitles called *.SMI...
You should be able to convert it with a program like this:
http://doom9.org/Soft21/Files/Subtitles/sub2sami.zip
If you convert it properly just give the filename the same name to match your movie! For example: To go with Bean.avi call the newly generated file Bean.smi and put it in the same directory. Select captions in WMP and you should be able to turn them on now!
Good luck!
_________________
Tom Green Sucks!
<font size=-1>[ This Message was edited by: danmanx on 2001-08-18 10:39:25 ]</font>
Simple bit rate question
By Bully9 in forum Newbie / General discussionsReplies: 5Last Post: 8th Jan 2009, 12:01 -
AviAddXSubs simple question (hopefully!)
By vladman2nd in forum SubtitleReplies: 1Last Post: 8th Jul 2008, 01:01 -
Simple Mplayer Question
By Maikeru-sama in forum Newbie / General discussionsReplies: 6Last Post: 29th May 2008, 21:10 -
question about how to remove simple software
By jimdagys in forum ComputerReplies: 2Last Post: 10th Apr 2008, 11:15 -
Simple Question: True or False?
By jcm0320 in forum Capturing and VCRReplies: 10Last Post: 23rd Aug 2007, 22:33
