Hi!
Just changed OS from win2k to winXP.
When I try to watch anything through the TV-out, it wont display.
The desktop shows fine on my TV-set, it's just the window with the movie that is black.
I've tried different gfx drivers, different movies, different formats, different players. Allways the same.
I've tried fullscreen and changing the resolution, no good.
As i said, the desktop shows fine, and games I play, but not the actual movie. It plays fine on my monitor...
It all worked perfectly in win2k.
HELP PLZ!!!
Try this:
Display Properties, Adapter Settings, Advanced. You should have a "Displays" tab where you can choose your primary display. It appears that you have PC monitor set as your primary display. Change that so the TV is the primary display. This should work, but in case it doesn't please let people know what kind of graphics card you have.
PhArAoHWinners never quit, quitters never win. Those who never win and never quit are idiots. -
Yeah, it worked!
But now its not showing on the monitor, but thats ok.
Thanxs alot.
Wierd that movies displayed fine on both monitor and tv at the same time just fine in w2k.
well, well.
I'm happy now.
If you want to view teh movie on both TV and PC monitor then you should make both displays "Primary".
Using Nvidia's 40.41 that is not possible(?).
If I set one display as primary, the other one changes to secondary.
Anyway, thanx. -
Thats wierd... I have this problem in w2k.
And what is really wierd is that it worked a while ago and now it doest.
And there must be another solution than changing the TV to primary
Hmm... if I think about it, I have installed Service Pack 3.... maybe that is the problem here...
will tell you later it that solved the problem or not -
tv.tool 6.8 didnt solve it...
...but changing the TV to primary did. But now the player is black on my monitor instead....
So I will go for this till I have time to uninstall SP3
Help! Cannot rip this DVD - wierd problem...
By Comfy in forum DVD RippingReplies: 2Last Post: 8th Dec 2009, 10:10 -
WIERD DVD data disk problem
By bruinflight in forum Newbie / General discussionsReplies: 24Last Post: 24th Sep 2009, 23:53 -
More wierd Vista behavior...
By ahhaa in forum ComputerReplies: 2Last Post: 28th Jun 2008, 20:05 -
Wierd REWIND Problem... on standalones only!)
By taboo in forum DVD RippingReplies: 4Last Post: 16th Feb 2008, 21:29 -
Help! Wierd problem of Sharp Aquos 46D64U
By cryogenics in forum DVB / IPTVReplies: 3Last Post: 3rd Dec 2007, 22:56
