im converting divx movie into two mpeg cds using tmpeg and virtual dub.
first I extract a wav file, then in tmpeg select the divx movie as video, and wav as audio and select the source range in the middle. ive come out with a perfect cd1, and cd2 will crash windows media player every time. what is wrong with cd2 ?!
When does it crash in the second half ?
Did you use Vdub to scan for junk frames first ?
Load your second mpeg into TMPGEnc > File > Mpeg tools
Select split merge and "Mpeg 1 Video CD" from list
Add your mpeg and select an output name/path
Click run
Streaming it though TMPGEnc like this, may fix the problem
You could have converted all the AVI and split it later !
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 10:32 -
MPEG DV prob
By mainegate in forum ffmpegX general discussionReplies: 0Last Post: 24th Aug 2007, 18:01 -
DirectShowSource prob for AVI(DV) to MP4
By sekaiji in forum Video ConversionReplies: 3Last Post: 29th Jun 2007, 19:43 -
avi to mp4 with MeGui prob...
By sekaiji in forum Video ConversionReplies: 2Last Post: 29th Jun 2007, 17:48 -
AVI audio prob or video
By SilverDales in forum Video ConversionReplies: 8Last Post: 25th Jun 2007, 16:50
