If I want to make a VCD with Nero to play in my standalone everything is OK, BUT, I want make a VCD that is CDi compliant and Nero wont do this... It will play the first track then wont go on to the next track, does anyone know any software that will make CDi compliant VCD's. I know CDi's are old technology but some people do have them.(Oh by the way there is a check box in nero that indicates that you can make it CDi compliant. I went to the Nero website where it tells me that CDi is unsupported....go figure!)
Definitely with VCDImager if you add the CD-i app...
http://www.vcdimager.org/guides
Regards.Michael Tam
w: Morsels of Evidence
WD TV is HDCP compliant?
By Supremo316 in forum Media Center PC / MediaCentersReplies: 1Last Post: 20th Nov 2009, 20:29 -
Wish to convert from .TS to compliant MPEG2
By gabier in forum Video ConversionReplies: 28Last Post: 9th Jul 2008, 04:34 -
making a compliant resolution mpeg2 file from a non-compliant .mkv file
By dwisniski in forum Video ConversionReplies: 1Last Post: 7th Mar 2008, 07:49 -
Anyway to make a non compliant disc compliant?
By zanos in forum Authoring (DVD)Replies: 9Last Post: 23rd Feb 2008, 11:46 -
HDMI compliant?
By vanjo in forum DVB / IPTVReplies: 6Last Post: 16th Oct 2007, 21:47
