    Aug 2001
    Boston
    I am capturing TV shows at DVD quality for eventual burn to removable media and would also like to re-encode at a lower bitrate to post on my server and/or burn as SVCD's. Here's the workflow:
    ___ Burn DVD
    DVD Quality Capture -- |___ Re-encode at lower bitrate -- Post
    What are my options for the re-encoding? Do I need to de-mux then re-encode using something like TMPGEnc?
    -mkirk
  2. Member DJRumpy's Avatar
    Dallas, Texas
    Demux, and re-encode the audio to 44.1Khz
    You'll have to resize the video (TMPGenc, or CCE) if your not using a CVD, or VCD compliant resolution (352x480 for VCD, or 352x240 for VCD). Both of thoese resolutions are also valid DVD resolutions.
    I would suggest demux, change freq of audio using headac3, and resizing to your target resolution (480x480, 352x480, 352x240).
    Keep your source capture files, if they are avi, to save the quality loss you'll experience if you go from MPEG --> MPEG
    Aug 2001
    Boston
    Ok-
    I can use TMPGEnc to de-mux the source MPEG file to a .m2v and .mpg file (video and audio). How do I then re-encode the video file at SVCD or VCD spec (I KNOW the spec but how do I basically go from MPEG > MPEG?)
    I do not have a source .avi file -- my original source is captured directly to MPEG2. That's the dilema -- I need to go from MPEG (dvd spec) to MPEG (svcd spec).
    Any help out there at the workflow I need to follow?
  4. Member DVWannaB's Avatar
    Dec 2001
    You will need a tool called DVD2AVI. Go to TOOLS section in brown panel section (left of your screen). Download it (free). Use it to FILE---->OPEN your M2V file. Then FILE --->"Save Project"----->name the file. It will have a D2V extention, which is read by TMPEGEnc. Alternatively, use the guide in the HOW TO------>CONVERT. Its very simple and fast.
