this is a basic dvd to divx guide that will hopefully help some newbies out.
its is basic with no pics. but if someone is interested in sprucing it up that is fine.
How to rip a dvd to divx
Programs u will need
Smartripper
DVD2AVI
Vob2Audio
Virtualdub
I make a new folder on my desktop and do all my work into it to make things simple
First thing u need to do is play the dvd for a few seconds
Then open Smartripper
Under settings(Movie Tab) make sure u have these checked.key-check(every vob), file-splitting (every vob), under options check these create list-file, unlock drive, demacro,copy ifo-file, and create info-file. Vob access should be auto. Select your target folder and start.
Next open DVD2AVI
click file, open and find your folder where u put the smartripper vobs files at and select the first vob file. u will see a box open with all the vob files then. select ok. under the audio select none for the track number(we will do audio next)
then click file and save avi, then u will get a little dialog box popup. under compression select your divx codec and then click config. I use 1-pass and usually set the kbps between 700-800. click ok and then set your target folder for the divx.
Next open Vob2Audio
click voblist and find your folder where u put the smartripper stuff at. select the list file (should be the only 1 the program see's) and then look in audio stream. if u dont see any streams u need to close the program and opne the folder where smartripper put the stuff in and u will see a new batch file. run that batch file and u will have the audio streams now. under audio streams it will be the first stream made in english. slect your target file and start
Next open Virtualdub
click file and find your new divx file
under the video tab make sure u have direct stream copy checked
then click audio and click wav audio. find your audio file that vob2audio made and select it. then click audio again and go to full processing mode, then click audio again and click compression. find your mp3 codec and then select a compression u want, generally use 128 either 44100 or 48000 ok click file, save as avi, select your target folder and your done.
if u have any questions, comments, or suggestions please feel free to let me know
Thankz, AlRiGhTyThEn
you really wanna help out some newbies?
send them to vidomi.com
******* easiest (soooo easy) way to create divx movies with quality results.. a little bit of tweaking, and you've got a masterpiece on your hands.. -
You want the best QUALITY for your DivX....
http://www.doom9.org/divx-encoding.htm
Maybe you chummers learn how to use Nandub
Until I have the profile that lets me play Mpeg4/DivX on DVD-units I will keep using Nandub. And yes DVD-units are coming out that support Mpeg4.
Vidomi is crap compared to Nandub or even DivX 5.02 Pro 2pass w/ Virtualdub. And lets not forget XviD 2pass w/ Virtualdub 8)
Easy does not make for the best QUALITY :PiAMD64. µ
The World is changed, Some say Awakened.
It's 13:53:33 . Do You Know Where Your Meat Body Is?
Shadowrunner by trade... -
Start a new thread if you want to ask a question, and only post it in one forum.
Edited by Craig Tucker
TV Guide/Guide Plus+ After Feb. 2009
By handyguy in forum DVB / IPTVReplies: 0Last Post: 30th Oct 2008, 10:34 -
Guide for creating Divx/Xvid DVD Rips Easily on a Mac?
By ehmjay in forum MacReplies: 4Last Post: 7th Oct 2008, 17:03 -
Looking for guide: TV Episodes to DVD!
By munchgrunch in forum Video ConversionReplies: 3Last Post: 15th Jul 2008, 23:19 -
DVD Author Guide
By brvignesh in forum Authoring (DVD)Replies: 1Last Post: 11th Dec 2007, 08:39 -
DVD Rip Guide
By brvignesh in forum DVD RippingReplies: 11Last Post: 5th Dec 2007, 08:18
