can everybody reading this post please leave a reply saying in their
own opinion the best dvd-r media you can buy for the pioneer 104.
or the ones you use with no trouble.
thanks in advance. thingimijig.
Results 1 to 13 of 13
Do a search and you'll find alot if info pertaining to media.
Personally I am using the TDK 2X DVD-R and have not had one problem on either of my 2 Sony's, 2 Samsung's or my old Panasonic
I just made a bulk order which arrives today and will keep advised soon as I make a few DVDs -
maxell was rated first in a test published on pioneer's web site .
apple media was rated second
above is for dvd-r disks
i use apple disks exclusivly ..
do a search on this forum for media and that link to pioneer study is here somewhere -
Here's the link you need. http://www.pioneerelectronics.com/Pioneer/CDA/Common/ArticleReviewsDetails/0,2651,92097,00.html
I use branded tdk since it is fairly cheap and very reliable, I have used about 200 with no problems. Verbatim and maxell are also very good but usually a little more $$. I have been using lead data media lately with great success. Out of 50 have had no issues at all, they are only 1x but cost about .85 cents each. I quit using princo media after too many bad discs. -
Received my bulk order of 100 Ritek Silver v2.0 1X and have not had a problem in the 8 that I have burnt so far
Works on all the aforementioned drives
Never made a coaster with TDK DVD-R's
Apple works also
Compusa had TDK on sale $2.99 each
I've heard the horror stories so I've stayed awya from generics. -
Depends on where you are in the world as to what media is available. In the U.K. there are a few websites which allow you to pick a few of each of their generic media and branded discs. Apple are hard to come by.
TDK 1x are usually perfect and cheap at £1.20. White Label and Datasafe gen 2 need looking at before use. Check the bottom of the disc in daylight for flaws in the dye. blankdiscshop.co.uk will take back any unused media within 30 days. It also depends on what you are doing with the discs. To play on a standalone you have to try various media to see what works. A computer dvd rom is much more forgiving. -
I am in UK and have been using Datasafe Gen3 2x Media from www.digitalpromo.co.uk at £1.19 each. Absolutely great no coasters yet!
I use CompUSA brand DVD-Rs and a Pioneer RW, I'm having a little trouble with an Imation RW (It has trouble completely erasing)
-Smd -
I agree that TDK's are the way to go. You can buy them in bulk on eBay for about $1.90 each. I have been burning 4gig movies in 22 minutes without a hitch using the (internal A03). I also used the media identifier tool and they show as TDK even though TDK says they aren't. Who cares as long as they work. They don't work in my external usb A03 in any of my computers for some reason so I have to use other discs for that.
How To Convert DVD Media Made From VHS Media For Sharing Online
By BlazingSpeed in forum Video Streaming DownloadingReplies: 0Last Post: 11th Dec 2010, 14:20 -
DMR-EZ27 records on rewriteable media, but gives U61 error on other media!
By dr-rjp in forum DVD & Blu-ray RecordersReplies: 2Last Post: 11th Jun 2008, 18:58 -
Replace Pioneer DVR-104 with DVR-115D? EIDE cable the same? Other questions
By Goldenvoice in forum DVD & Blu-ray WritersReplies: 1Last Post: 13th May 2008, 08:20 -
Does Pioneer DVR-112D burn DVD+R and DVD+R DL media well?
By palmtree in forum DVD & Blu-ray WritersReplies: 26Last Post: 4th Jan 2008, 04:22 -
What is the best DL media for Pioneer 1810 and DVR-710 drives ?
By MacPCConsultants in forum MediaReplies: 9Last Post: 2nd Dec 2007, 14:37
