I try to convert a divx file (81.07 fps;544 x 244;42 min) to mpeg to burn it as a vcd. The playing time of this movie is about two hours.
When loading Tempgenc with a 25FPS and a bitrate of 1150, the mpeg will be enormous. Adjusting the bitrate helps, but quality will then be poor. Who can help ?
Dutch
If you really must fit 2 hours on one CD, use a bitrate calculator (tools, left of page) to get a bitrate that will fit, with subsequent loss of quality. Alternativly, search these forums for kwags templates to see if you can find one that suits you.
Hope this helps -
It looks like your AVI header information is messed up. You say the movie is about 2 hours long but the AVI info says 42 minutes with a 81.07 fps. I think the actually framerate should be 29.97 fps
(81.07fps x 42min)/29.97fps = 114 minutes
You should use VirtualDub to fix the framerate first. A 2 hour movie on one disc isn't going to look very good no matter what you do. You best solution is to put it on 2 disc.
-LeeBear
Encoding a Video-Divx got Size Problem...
By PzSniper in forum Video ConversionReplies: 3Last Post: 17th Sep 2009, 17:59 -
Seagate HDD - Extraordinary Event
By blinky88 in forum ComputerReplies: 2Last Post: 2nd Feb 2009, 10:36 -
Problem with Vob to DivX Coversion Image Size
By Baggins in forum Newbie / General discussionsReplies: 7Last Post: 8th Oct 2008, 13:50 -
problem converting mpeg 1 to divx
By goingape in forum Video ConversionReplies: 11Last Post: 9th Jan 2008, 14:17 -
MPEG to Divx audio sync problem
By starless in forum ffmpegX general discussionReplies: 8Last Post: 11th Oct 2007, 04:38
