i have downloaded some svcds and they wont play do i need a codec and which 1 if i do?
You should try installing an MPEG2 codec. VCDs are MPEG1, SVCDs are MPEG2. Unless you use PowerDVD, WinDVD, or a hardware MPEG2 decoder, you are going to need the codec.
I use the Elecard MPEG2 codec, which is linked for download in the "Tools" section of this website.
Hope this helps
Prospero
If a DVD/CD will only play on the computer...
By LellyB in forum Newbie / General discussionsReplies: 8Last Post: 10th Sep 2010, 07:38 -
How do you play music on the computer using all 6 speakers?
By Obamargarine in forum ComputerReplies: 5Last Post: 10th Mar 2009, 16:40 -
WMP9 Plays M2TS BlueRay
By wulf109 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 30th Dec 2008, 19:10 -
Burned DVDs only play on my computer
By kissy in forum Newbie / General discussionsReplies: 16Last Post: 7th Jan 2008, 12:48 -
want to play VTS_01_0.IFO with wmp9 under win2k
By vobnovice in forum Software PlayingReplies: 3Last Post: 7th Jun 2007, 12:31
