Some people say that 16:9 Display will look stretched and full-screen when viewed on a 4:3 T.V? Is this true? I have a APEX AD-1500.
16:9 looks fine on a 4:3 TV as long as you keep the aspect ratio. If u try to change it to 4:3 thats when it looks all stretched. Obviously if u keep the aspect ratio there will be bars top and bottom.
Fozzee -
Have you heard the term "letterboxed" before. That is what 16:9 is when played on a 4:3 TV set.
It depends on the player. For DVD playback every player will automatically add the black bars to maintain the 16:9 aspect ratio. For (S)VCD playback that isn't the case. Most player won't add the black bars so everything will look stretched. Other players will not distort the image but just zoom in the middle and cut off the left and right sides of the picture. If you are thinking about using 16:9 aspect ratio for (S)VCD I suggest you make a sample CD and see how it displays on your player.
-LeeBear
Playing Video on display 2 and display 1 goes black
By sidewaysdriver in forum Software PlayingReplies: 2Last Post: 3rd Aug 2010, 01:36 -
1:1 signal display?
By khorven in forum DVB / IPTVReplies: 1Last Post: 28th Aug 2009, 12:32 -
BSOD while trying to display
By src2206 in forum Software PlayingReplies: 7Last Post: 11th Jun 2009, 14:27 -
TV Display Problem!!!
By tcheema in forum DVB / IPTVReplies: 5Last Post: 20th Feb 2008, 13:01 -
HD display question
By LT9000 in forum Newbie / General discussionsReplies: 1Last Post: 7th Dec 2007, 19:15
