I have a couple of VHS movies I bought while travelling in Europe that I'd like to convert from PAL to (S)VCD. My DVD player has no problem playing PAL/NTSC, but I only own an NTSC VCR. I do know of a Video conversion place just down the road that could do it for $25 per cassette, but I'd rather have the capability to do it myself. Does anyone know if it would jsut be best to buy a PAL VCR and hook it up to my analog in card(AverStereo) or is there some kind of PAL-NTSC converter that I could get like at Radio Shack or something?
You tested it on your VCR ?. Our European VHS players record in PAL but playback both. I had the problem the other way around, needed to convert a PAL into NTSC (VHS) for someone in the USA, in the end I recorded the PAL VHS onto the PC and converted it to NTSC (VCD) with TMPGEnc.
Your tape is PAL 50, so make sure anything you get is the same, some have PAL 50 in PAL 60 out, there are all sorts of combinations, same for DVD Players.
Next time buy DVD's then rip them
. You need to visit your local electrical stores to see what's available, or update your VHS to a newer model if it wont play PAL
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
How to convert a PAL VHS into NTSC VHS or DVD?
By coody in forum Video ConversionReplies: 9Last Post: 22nd May 2011, 03:09 -
Convert PAL to NTSC VHS?
By manhnt in forum Newbie / General discussionsReplies: 4Last Post: 29th Jul 2009, 15:49 -
Newbie needs to convert NTSC VHS tapes to PAL DVD
By mcullen8320 in forum Newbie / General discussionsReplies: 3Last Post: 13th Nov 2008, 14:51 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
