When I create an image from ifoedit the img is incomplete.
It looks it needs a logical seq of ifo and vob files. But my main movie is in vob 13.
So
1) Is there a way to get the vos in seq ?
I now have the video_ts, vts_1, vts_4, and vts_13 (with related ifo/vob files)
how do I get vts_1, 2, 3
2) alternative: can I fill up the missing entries with dummy ifo/vob from another movie (very small ones of course)
If you have a menu and it works on your hard disk, why not try and burn it to a DVD-RW? I'm not sure if the other files are required.
IF I burn it like this it with eg Nero it works fine on my Yamakawa (Sampo) & PC but it fails to load on my Cyberhome.
That's why I want an image first so I can burn with DVDDecryptor -
Hi,
If your main movie is vts_13 then you must have vts_1 to vts_12 for imgtool to work. It will end if there is a gap in the numbers.
I had the same problem and I had to create empty vts_?? files.
hope this helps.
how to author incomplete VOB
By Banleno007 in forum Newbie / General discussionsReplies: 3Last Post: 15th Feb 2012, 19:44 -
Incomplete Defrag
By bevills1 in forum ComputerReplies: 21Last Post: 9th Jan 2009, 21:57 -
Incomplete video
By jace89 in forum Newbie / General discussionsReplies: 13Last Post: 14th Aug 2008, 18:49 -
DVD Shrink to VOB,IFO, BUP and then IMGtool to ISO, bigger than 7GB
By opieandy in forum DVD RippingReplies: 3Last Post: 28th Sep 2007, 15:04 -
ImgTool Files Too Large
By opieandy in forum Authoring (DVD)Replies: 4Last Post: 27th Sep 2007, 21:08
