Is there really no way to burn 95 minutes on 1 vcd?
Results 1 to 9 of 9
THE ONLY WAY WOULD BE TO LOWER THE BITRATE SO 95 MINUTES WOULD FIT ON A 700MB CD BUT AS YOU LOWER THE BITRATE THE QUALITY WILL LOWER ALSO. YOU CHOOSE THE LESSER OF 2 EVILS
But burning a vcd doesnt depend on size and quality, does it? it does depend on the time the mpg lasts i thougt?
Yes there is a way. I've been using KWAG templates for a month now on DVD-rips. Go to http://www.kvcd.net and read some of the forums. I've had up to 116minutes on a single 80min cd. Worth a go.
Frankanger -
Not without breaking the standards.
You could use a 99 minute disk, but there are only a few burners that can use them and even fewer DVDplayers that could play them all the way through.
You could encode to a non-standard template as suggested above or you could cut it into two .mpg files for easy placement on two 74minute or larger disks. -
Yes, if you lower the bitrate to say, 900 for 100 minutes or 950 for 85 minutes.. (depending on some other factors..)
I did it and not much loss of quality...and if you want this sort of thing that is what you get. :PProud Canadian -
Originally Posted by sebastiaan
http://www.kvcd.net/forum/viewtopic.php?t=1211
Enjoy,
-kwagKVCD.Net - Advanced Video Conversion
http://www.kvcd.net -
SO you have to convert the mpg in that quality, and then you can burn it on a vcd? But what about nero not accepting such an mpg as a vcd format?
How about 180 minutes
Enjoy,
-kwag
Dear KWAG, I have been ripping and burning as much as 100 minutes on an 80 minute VCD using the ususal Smartripper/DVD2AVI/TMPGEnc/VCDEasy......so now if I donwload your template, what is required? Do I have to convert the audio separately? Can I convert 180 minutes onto an 80 minute CD as you profess?
Please outline instructions in detail...and if it works...YOU are the BEST..awaiting your reply....Proud Canadian
Need a DVD 30 minutes after the game?
By Telemov in forum Newbie / General discussionsReplies: 56Last Post: 15th Feb 2012, 21:39 -
Only convert the first 10 minutes or so ...
By GMUET in forum ffmpegX general discussionReplies: 4Last Post: 8th Jun 2011, 14:13 -
Creating Chapters every few minutes
By Subhash in forum Authoring (DVD)Replies: 23Last Post: 6th Mar 2010, 09:44 -
How to shut down harddrives after 20 minutes
By mysts in forum ComputerReplies: 2Last Post: 20th Jan 2010, 02:19 -
Video crashes after a few minutes
By Diego123 in forum Software PlayingReplies: 16Last Post: 4th Jan 2008, 10:04
