I have no problem playing regular (128kbps and up) MP3s on this machine, but I have a lot of Howard Stern shows ( no comments from you Jackie fans please) that I want to burn and would like to keep the bitrate as low as I can, but still be able to play them on my APEX. Anyone know what the lowest bitrate is that will work? Has to be higher than 32...I've already tried that. TIA!
Whats wrong with burning them at 128kbps dual-channel stereo? You'd be able to fit a little over 10 hours of material onto a 650mb CD (which is 9h59m more than necessary).
hehehe
p.s. Anything lower than 128kbps and you should go mono. I get an incredibly full sound when encoding at 96kbps mono for movies I play back on my work computer. When I played the same movie through my home setup with subwoofer ON, the bass really boomed, moreso than in normal stereo mode. Go figure.
<font size=-1>[ This Message was edited by: AntnyMD on 2001-08-15 12:41:36 ]</font> -
Thanks, but you didn't really address my question. All I need to know is "What is the minimum bitrate an APEX-703 will play?" If I want to play it on my computer I can use what ever bitrate I want.
How to set MINIMUM bitrate in VBR 2 -pass on TMPGEnc Authoringworks 4
By eltimbomofo in forum Authoring (DVD)Replies: 3Last Post: 9th Mar 2012, 15:59 -
Minimum Bitrate MPEG2 encoding
By Rob D. in forum ffmpegX general discussionReplies: 4Last Post: 14th Jul 2010, 09:44 -
minimum configuration for 1080p
By xenotox in forum Media Center PC / MediaCentersReplies: 26Last Post: 30th Nov 2009, 15:31 -
maximum editing, minimum conversion?
By meganann in forum EditingReplies: 4Last Post: 30th Dec 2008, 00:17 -
Minimum Reqs For HDTV PC
By JBreits in forum Media Center PC / MediaCentersReplies: 13Last Post: 17th Oct 2007, 15:26
