i hope someone can help, i downloaded the svcd demo from this site and burnt it to a disc using the bin/cue way of burning, this i had never done before but it worked and played fine on my dvd, so i decided to try and make my own, i encoded a film to mpeg2(using tmpge) and burnt the disc using nero but i burnt it the normal way, exited out of the wizard and chose super vcd from the list, i burnt the disc no problems, but when i put it in the dvd player nothing happens, it recognises there is a film on the disc as it displays the time, but i will not play, i just get a black screen, please someone help as i am fast running out of discs!!!
thanks pete(again)![]()
Pete,
Double check that NERO is set for your TV system format ( pal or ntsc ). Also check the DVD player comment sot see if there are any known problems/workarounds that may need to be used.
Or you could just use VCDeasy and save yourself the hassle. -
still no luck, i checked everything was set probably and it was, i made a slight mistake in the fact that i said the svcd demo worked ok, infact it did not as the sound kept stuttering, i have now managed to get an svcd to play but again the sound keeps going on & off, does anyone have any ideas, i have tried 2 brands of media & i am burning at 2x
thanks pete -
yes it does say ist compatible, i have now started another thread as i have got a bit further but still have problems.
thanks pete -
please see my new thread................
http://www.vcdhelp.com/forum/viewtopic.php?p=330477#330477
thanks pete
Tivo to DVD Burning Issue
By jdogg2603 in forum Newbie / General discussionsReplies: 21Last Post: 7th Jan 2010, 06:27 -
burning issue
By jfree in forum Newbie / General discussionsReplies: 6Last Post: 20th Nov 2008, 02:06 -
dvd architect burning issue
By merray in forum Authoring (DVD)Replies: 1Last Post: 8th Nov 2008, 01:38 -
Read Error Issue with Burning
By Evhmoon in forum Newbie / General discussionsReplies: 4Last Post: 10th Feb 2008, 09:39 -
Strange colour issue when burning an MKV
By baldrick45 in forum Authoring (DVD)Replies: 2Last Post: 23rd Sep 2007, 17:52
