If I have an MPEG 2 plugin for one product, can it be used by another ? For example, if I have Adobe Premier with MPEG 2 plugin, can I point Sonic Foundries Video Factory to that plugin to encode in MPEG 2 ? Can I point TMPG ? Or must the plug-ins be developed for that software...
Not as dumb as it sounds because I dont know if these use common API's or they are program specific.
Thanks again...I ask because I need it for Sonic and TMPG but think I only have it in ADOBE ...UGGG
naw, i don't think you can do that. 'tis a perfectly valid question, but no.
basically all the plugin does is hack your .ini or .cfg file to allow those kinds of encodes, so your Premiere mpg2 plugin won't correctly hack your tmpgenc ini.[img=http://www.undeniablygeek.com/gir/pictures/official/IZ_Logo_optimized.jpg]
Probably a dumb burning question
By neroguy in forum Newbie / General discussionsReplies: 14Last Post: 7th May 2011, 05:34 -
Dumb PS3 Question
By wulf109 in forum DVD & Blu-ray PlayersReplies: 10Last Post: 4th Feb 2009, 08:56 -
Dumb PS3 Question
By wulf109 in forum Off topicReplies: 2Last Post: 3rd Feb 2009, 23:36 -
Really dumb USB 1.1 Question
By ahhaa in forum ComputerReplies: 4Last Post: 1st Jan 2009, 16:50 -
Dumb question about 768p
By winterwolfes in forum DVB / IPTVReplies: 28Last Post: 2nd Jan 2008, 17:50
