I have a problem with virtual dub. When I do a direct stream copy, not Full Processing mode, of the audio (copy the audio from a video into a wav file), it never saves all the audio. Example: I had a 32 minute video and it only saved 27 minutes of it. I can't do full processing mode, because it is AC3 audio, and i have to convert it to wave. how can i fix this problem or is there another good program that will let me strip the ac3 audio so i can convert it to wav myself. please help me.
http://www.digital-digest.com/dvd/downloads/virtualdub.html
Scroll down to the AC3 version."Today is only yesterdays tomorrow" -
Originally Posted by Xenogear900
This should not happen, did you check the AVI for junk frames, any problems will cause the save to abort.
Video > Scan Video stream for errors
If it finds any;
Video > direct stream copy
Audio > direct stream copy
SAVE AVI
if it crashes
use Vdub MP3
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 07:36 -
RipBot264 Audio Problem (no audio)
By fefalas in forum Video ConversionReplies: 9Last Post: 8th Apr 2011, 11:39 -
Help With Audio Problem please!
By heidilynn08 in forum AudioReplies: 3Last Post: 16th Dec 2010, 12:08 -
no audio what is the problem?
By Remyisme in forum Newbie / General discussionsReplies: 2Last Post: 11th Dec 2008, 03:28
