Has anyone else had this problem? I'm trying to encode with CCE 2.64, using 3-pass vbr. It always crashes right after completing the first pass.
Any suggestions?
It took me sooooo long to find a working version and 'patch'.
Hints regarding this issue haven't been very helpful. -
Does it "Crash" or give and error that your stream has changed? What is your source?
Do you have an MPEG2 codec installed on your system?
After a recent re-install of Win2K, I found CCE would crash or shutdown by itself -- it had never done that before. I got to thinking, "What's different this time around?!" and the only thing I could come up with was the lack of an MPEG2 codec (I had not gotten around to reinstalling PowerDVD yet). So, I reinstalled PowerDVD and viola, I have not had a single problem with CCE since.
Whether or not that was the cause, it solved my problem. -
It's an actual crash. I've got an MPEG-2 decoder installed. The same process works fine with CBR. This only happens with VBR.
I think Truman is on the right track. -
I would suggest you contact Cinema Craft and tell them of your problem
Probably hard to do since I don't think they support the 'cracked' version
Truman's right your crack is bad, but I wouldn't know anything about that since we all run legit copies
-LeeBear
meGUI crashes whenever it tries to MUX and only if its 2 pass =/ Help Pleas
By Chrushev in forum Video ConversionReplies: 2Last Post: 5th Jan 2010, 04:38 -
Does powerdirector have 2 pass VBR?
By perfection in forum Newbie / General discussionsReplies: 1Last Post: 24th Jul 2009, 23:49 -
question about vbr v/s cbr and 2 pass vbr
By perfection in forum Newbie / General discussionsReplies: 4Last Post: 14th Dec 2008, 03:55 -
DVDA 4 can do 2-pass VBR?
By itsme1 in forum Authoring (DVD)Replies: 4Last Post: 14th Jul 2007, 23:24 -
Need help with ffmpeg 2-pass VBR encoding
By SliderVF14 in forum Video ConversionReplies: 8Last Post: 14th May 2007, 18:03
