Audio and video are ready to mux. What can I use to mux them together and split out files that will fit onto two cds?
I'm trying to get XVCD. Used DVD2SVCD and things worked slick accept that the audio cuts out in the resultant muxed files. The mp2 file looks good. The mpv file looks good. How can I mux the two files together AND split the files for two cds?
Is there a GUI for doing this via bbmpeg?
Yes you can mux your video and audio file in bbMPEG and also set it to cut to fit into CDR. If you haven't read please follow this Guide.
http://www.vcdhelp.com/bbmpegedit.htm -
After a few tries I successfully muxed the files created by DVD2SVCD. Had to increase the mux rate in bbmpeg before pts/dts underflow errors went away.
Not sure why DVD2SVCD created these problems but it would have been nice to have the ability to manually increase mux rate within bbmpeg via DVD2SVCD to fix the problem. Having to do this manually sucked.
I've read about others having this problem. I'm I the only person using DVD2SVCD to make XVCD's?
BBMPEG Multiplexer Question
By Krelmaneck in forum Newbie / General discussionsReplies: 16Last Post: 23rd Apr 2011, 00:59 -
AVI-MUX: How do I mux avi file with a setting of "preload=512?"
By Stealth3si in forum EditingReplies: 3Last Post: 1st Feb 2010, 11:10 -
bbmpeg xp patch , page not found
By rabbit_hgc in forum EditingReplies: 8Last Post: 15th Jul 2009, 06:45 -
MUX Help (newbie)
By thisisjontheman in forum ffmpegX general discussionReplies: 2Last Post: 19th Oct 2008, 09:52 -
h264 + ac3... .mkv mux in synch, .avi mux out of synch...
By homerpez in forum Video ConversionReplies: 0Last Post: 5th May 2007, 06:42
