I use TMPGEnc frequently and never experienced the problem below.
As source, I use a 25 fps *.avi file. However the frame rate in the
"Source range" window of TMPGEnc shows 30 fps (top left of the window) if the "DirectShow File Multimedia Reader" priority is set to 1 in the "Enviromental settings" (VFAPI plug-in).
When this filter's priority is set to 0 or -1 (default), the "Source range" shows 25 fps (top left of the window).
Can someone confirm (and possible explain) this?
TIA
Results 1 to 1 of 1
30fps --> 24fps WITHOUT pulldown
By agni451 in forum Video ConversionReplies: 4Last Post: 4th Apr 2012, 23:25 -
Shoot 60fps or 30fps for YouTube?
By vid83 in forum Video Streaming DownloadingReplies: 5Last Post: 18th Jun 2011, 13:42 -
30fps VS 29.970fps
By bdr13278 in forum EditingReplies: 3Last Post: 18th Aug 2009, 19:10 -
Converting 30fps to 29.97fps ?
By blewyn in forum Video ConversionReplies: 2Last Post: 19th Mar 2008, 11:24 -
Converting from 120fps to 30fps
By shorto in forum Video ConversionReplies: 6Last Post: 22nd Feb 2008, 12:51
