My main goal is to make home dvd movies. I have a JVC DV camcorder that has 1394 and a Pioneer dvd burner. My pc has plenty of horsepower and hd space. What do I need to do this.
hardware
software
etc.
since you are in the same boat as me... i'd recommend pinnacle dv studio... its a good beginners package. Does editing and dvd burning.
more advance you may want to try Adobe Premiere or Video Vegas 3.0 for editing. Try MyDVD for authoring.
I haven't done much authoring since I haven't gotten the dvd burner yet (less than a week) but I plan on trying EZ CD Creator, MyDVD, and others
good luck -
Don't forget you also need a capture device - if your Camcorder has a firewire connection then you should just need to install a FireWire card in the PC.
my bad... i read his post as having a firewire card already.
Pinnacle Studio DV is a good beginners package because it includes the firewire card. It has been approved by JVC as well.
there are many other choices though -
ok heres the scoop. I have pinnacle studio 8 and have made a couple videos already but they really suck. I like ps8 a lot but the quality of the dvd is terrible. There are vhs movies that are better. I would think since the camera is all digital and I am putting it on dvd that I would get a crystal clear picture. This is not happening.
Netman -
my guess would be the mpeg2 codec you are using. Adobe does have a trial version of Premiere.
Uninstall PS8 and try Premiere. I know my JVC (1 megapixel) has awesome quality.
Until I get my dvd burner I can't help you out much more.
When I get mine we ought to get together and test.
Capturing Help
By Kyoji24 in forum Capturing and VCRReplies: 4Last Post: 23rd Apr 2010, 07:37 -
What are you capturing?
By ryangarfield in forum Capturing and VCRReplies: 10Last Post: 20th Apr 2010, 15:16 -
capturing software
By fabpozzi in forum Capturing and VCRReplies: 1Last Post: 23rd Oct 2009, 08:04 -
Capturing help.
By fuseek in forum Capturing and VCRReplies: 0Last Post: 6th May 2008, 10:49 -
Capturing in HD
By The Sumerian in forum Capturing and VCRReplies: 1Last Post: 7th Jun 2007, 12:40
