Have been playing around with converting some dvd content to divx. I use XviD codec at about 850 Kbps. I notice that during any scene of high motion the screen pixelates badly and stays pixelated until the scene motion lowers. I using Flask to do the conversion. Are there any settgins either in the codec setup or Flask to at least lower this problem. Obviously the higher the rate i set the less obvious the problem is, but im guessing these groups who rip movies professionally, arent using high bitrates to fit movies on one cd. Any ideas would be appreciated.
Cheers,
HaZ
Results 1 to 1 of 1
x264 AVC High@L5.1 to High@L4.1 conversion
By Pr0metheus in forum Video ConversionReplies: 16Last Post: 11th Oct 2013, 15:37 -
[Q] Convert MKV Format Profile from High@L5.0 to High@L3.1?
By xIntenso in forum Video ConversionReplies: 5Last Post: 26th Aug 2013, 22:46 -
What is the difference between x264 AVC High@L5.1 and High@L4.1?
By Bonie81 in forum Video ConversionReplies: 9Last Post: 26th Aug 2013, 20:40 -
Gui dvd author-jumping movie in fast motion scenes due to high video bitrat
By extent in forum Authoring (DVD)Replies: 8Last Post: 19th Feb 2009, 08:30 -
Divx Bitrate Adjustment - Low Motion or High Motion? TmpgEnc Xpress 4
By Sliztzan in forum Video ConversionReplies: 5Last Post: 31st Aug 2008, 21:11
