hi all-
i dl a trial version of nero and when i load it up and goto burn using the wizard it gives me 3 burn options (1)cd (2) ddcd which is grayed out (3) dvd (I dont have a dvd burner)
My question is why does it ask me if i want to burn a dvd when i dotn have a dvd burner????? did i download the wrong version or soemthing???
THANKS IN ADVANCE for the HELP!!!!!!!!!!!!!!!!!!!!
Sr
It's just an option (for those who *do* have DVD burners) - why is this a problem?
thanks for the help. its not a problem (i dont think) but why would ddcc be grayed out and not dvd burner (i dont have a dvd burner) i thought that would be grayed out as well. the only problem is do i have the right version of nero. i guess it doesnt matter right? as long as i can goto to the menu and burn vcd, cd etc.... and not use the wizard.
There is an option in Nero to choose *Image recorder* instead of your writer. So you can in fact burn to DVD - as an image file. Although it won't be much use to you.
sillyrabbitt:
Yes, you do have the right version of Nero. There is an option in Nero to tell it not to display unsupported formats, but as banjazzer mentioned, you could (or might want to) create images in those formats and it certainly doesn't hurt having them available. -
banjazzer:
In case you haven't found it yet, it's on the Expert Features tab of the preferences. I'm an options/features nut, so I like to see *everything* I will be able to do, even before I have/had all the right hardware.
question about how to burn Nero Image
By jimdagys in forum DVD RippingReplies: 5Last Post: 4th Sep 2010, 11:06 -
Nero Recode question
By wulf109 in forum Video ConversionReplies: 1Last Post: 4th Aug 2009, 07:55 -
nero 8 question
By m-man in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2009, 13:38 -
Nero 6 audio editing question
By Rad17 in forum Newbie / General discussionsReplies: 2Last Post: 29th Jan 2009, 23:53 -
Nero 8 transcoding question...
By RaGuSNY in forum Video ConversionReplies: 3Last Post: 4th Nov 2007, 14:23
