Hi, I'm new at this thing (started this week-end!). I've used tmpgenc to produce the mpg file and it warns me that it's too big for the CD (using the wizard). How do I change that if I want to keep the same "quality" (the fields are grayed out ?!?). How do I span the file to fit on more than one CD?
Mike![]()
Hi fromoven,
I am also not an expert. The tools I use (DVD Rip to CD-R) are Smart Ripper 2.41, DVD2AVI and TMPGEnc. I had the same issue of fitting the movie to 2 disks. I do the job manually using paper and pencil. While using SmartRipper do not select all chapters. Select about 3-5 chapters manually. Keep a check on the time window. Ensure that the resultant decrypted VOB does not exceed 24 minutes. Thus for a standard movie, you will end up with about 5 to 6 VOB files. When these VOB files are encoded to MPEG1 in TMPGEnc, they will translate to a size that will match the number of minutes. This means that 3 files (assuming 24 minutes each) will fit on each CD-R (74 min).
There is no fixed answer. Usually a ballpark figure of 10 chapters of the DVD translate to 23 to 25 minutes of the movie. I manually calculate the chapter lengths and note down on paper such as:
VCD 1
1. VCD Chapter 1 --> DVD Chapters 1-9 --> 19'45"
2. VCD Chapter 2 --> DVD Chapters 10-19 --> 23'11"
VCD 2
1. VCD Chapter 5 --> DVD Chapters 29-39 --> 18'33"
2. VCD Chapter 6 --> DVD Chapters 40-48 --> 21'35"
etc.
Once, the above matrix is calculated by me, I start the actual ripping process. The above method is not elegant I admit and takes more time but I said earlier, I am new at this. Some of the pros here, might come up with a better answer.
One of the nice feature of the above method is, I can create menus with thumbnails and my own chapter names.*** My computer can beat me at chess, but is no match when it comes to kick-boxing. *** -
After you have made your MPG file, just use TMPGenc's "MPEG Tools" on the file menu to split the original into two pieces.
Thanks guys, I'll try that (at least I have some way out now and I'm less desperate!)
Mike
Multiple .VOB file to one file?
By neworldman in forum Video ConversionReplies: 12Last Post: 4th Jan 2017, 03:00 -
Merging multiple parts of one mp4 file into one file
By vaultedskies in forum Newbie / General discussionsReplies: 2Last Post: 16th Nov 2011, 10:08 -
Multiple SUBs on AVI file?
By poumtatalia in forum SubtitleReplies: 1Last Post: 6th May 2010, 04:15 -
Multiple AVI file for one DVD
By tim_ver in forum Newbie / General discussionsReplies: 5Last Post: 2nd Jan 2009, 04:45 -
Multiple screenshots from a video file
By Xeromem in forum Newbie / General discussionsReplies: 5Last Post: 11th Dec 2007, 13:44
