Okay, what's the point of buying a Widescreen TV if a NON-anamorphic DVD movie like this...
for those of you that have a Widescreen TV, does it really look like that on a non-anamorphic movie? hmm...i was thinking of getting a widescreen tv, butta after reading non-anamorphic dvd movies turned out to be like that, I'm now starting to change my mind.
Is it possible to make a vcd & svcd movie look great on both 16:9 TV and a 4:3 TV?
I heard that if you make a svcd Anamorphic, it will look good on a 16:9 TV, but it will look strectch on a 4:3 TV.
but then again, if you make your svcd non-anamorphic, it will look good on a 4:3 TV, and it will look like the picture above on a 16:9 TV.
you know, an Anamorphic dvd movie look great on both 16:9 and 4:3 TVs. but..how do i make Anamorphic Vcd & svcd which will look great on both TV's?[/url]
All of the 16:9 televisions I have seen have excellent stretch capabilities.
For example, I was at a friends house who has a 47' Toshiba Theatre Wide HDTV monitor and we watched a football game off of satellite in widescreen format and it did it excellently. The 4:3 broadcast looked good in 16:9-there were no visible distortions in stadium shots or shots of players. I was amazed. They said they watch everything in 16:9 (even VHS) and that it looks great.
So I wouldn't worry about non-animorphic DVDs...End of Line. -
I have a widescreen TV and about 250 DVd's. Two of them are non-anamorphic. The rest are anamorph or 16:9 anamorph.
Suppose you have a 231:1 movie. On a 4:3 TV set you will have 60% of black bars. On a 16:9 TV set, you will have 30% of black bars. So there is a difference.
All my SVCD's are anamorph. (about 500) It depends on the source you use. I never encode a DVD which is in 4:3 format.
If you want to have a anamorphic SVCD, just set the encoder to 4:3 function. This means that the picture will "squeezed" to fit in a 4:3 frame. The result is mostly that people get "eggheads" on a 4:3 TV. Well, thats anamorph. Your widescreen TV will stretch the movie again horizontally, and the aspect ratio is correct again. If you source is 4:3 however, then your SVCD will also be on 4:3 format. But if you have a movie in original format on DVD, and you will rip it, then the above method will show it's benefit in combination with a widescreen TV.
Most of my friend changed to a 100hrz widescreen TV, and no-one ever wants to go back to the 4:3 TV set's.The Dutchman -
Originally Posted by xzarkad
Does your non-anamorphic dvd's really look like the picture i showed you above?
well..then, how do i encode my SVCDs so it would look great on both 16:9 and 4:3 TV's? 8)
If you want to have a anamorphic SVCD, just set the encoder to 4:3 function. This means that the picture will "squeezed" to fit in a 4:3 frame. The result is mostly that people get "eggheads" on a 4:3 TV. Well, thats anamorph. Your widescreen TV will stretch the movie again horizontally, and the aspect ratio is correct again. If you source is 4:3 however, then your SVCD will also be on 4:3 format. But if you have a movie in original format on DVD, and you will rip it, then the above method will show it's benefit in combination with a widescreen TV. -
No non-anamorphic look correct, they are just a little softer then the anamorphic equivilent.
SVCD's do not universally support 16:9 enhanced mode, so if you choose to 16:9 anamorphic compression be warned that not all DVD players can letterbox them properly on output. -
On my early DVD rips I noticed that I got the egg head effect because I had encoded at 4:3. This plays great on my 16:9 TV because it gets stretched out again but luckily my 4:3 TV has a 16:9 option which puts black bars on the screen to resize a 4:3 picture down to a 16:9. I think most modern TV's have this facility (or maybe I'm just lucky).Originally Posted by xzarkad
I should mention that this only works when the source is 16:9 of course.
So one option is:
Encode your 16:9 DVD's in 4:3 to play on a 16:9 TV and use the 16:9 option on your 4:3 TV (if you have one).Eat! Drink! Be merry! Tomorrow we snuff it! - (Sid James, from 'Hancock's Half Hour') -
Finally someone with the same ideas
I always encode all my 16:9 movies to "anamorphic" SVCD's.
They look great on 16:9 TV's and with the 16:9-button also on 4:3.
knowing someday I'll buy a 16:9 tv, I think I will never regret that decision
And besides...16:9 stretched on 4:3 doesn't look that bad at all. Personally I prefer that above letterboxing or black-bars. -
I'm glad to see someone else has got a 16:9 button on their TV. I was beginning to think I was the only one!
Didi I just waste money on 64bit
By beavereater in forum ComputerReplies: 6Last Post: 1st Nov 2011, 11:59 -
.mkv to .avi to dvd, waste of quality?
By yodnnee in forum Video ConversionReplies: 2Last Post: 29th Jan 2010, 05:12 -
Dell Bans the Export of Electronic Waste to Developing Countries
By noemi7 in forum ComputerReplies: 0Last Post: 15th May 2009, 05:08 -
Did I waste my money?
By rcguy1 in forum Newbie / General discussionsReplies: 12Last Post: 6th Oct 2007, 01:32 -
did I waste my money?
By tina1138 in forum Newbie / General discussionsReplies: 6Last Post: 1st Sep 2007, 14:28
