I am trying to convert this SVCD to VCD, but it TMPGEnc gives an 'unsupported file error'. Virtualdub says 'Illegal Mpeg file'. I managed to get it to play in WMP last night (it wont play anymore!, and the video codec was
'Morgan Stream', or something. Whatever it is it wont open. Ive tried everything and every codec (Nimo, etc).. It does open up on WInDVD but just at a title screen... Anyone know what to do here?
Results 1 to 9 of 9
SVCD will not load into Vdub, there is no support.
Install Power DVD 4, this is 1 of 3 codecs that will ork with TMPGEnc Plus... -
I installed Power DVD and it plays fine, but TMPGEnc still says 'unsupported or cannot open'.
Frameserve it from dvd2avi into TMPG
~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards -
There may be a conflict with other mpeg 2 codecs on your system, you are using TMPGEnc Plus 2.58 ?Originally Posted by KevN2002
If your using the free one, you need TMPGEnc 2.55 < -
Im using TMPGEnc v2.57.41.142 right now.. I did try to install other codecs when I encountered this prob, how can I get rid of them and start over? Is that version of TMPGEng good?
Hi, No you need an older free version or the new Plus, try the older ones before you work on any codec removal. V 2.55 I think was when things changed.
What exactly is missing from the current version? Do you know why Im having problems with this particular mpeg?
What Im trying to do is convert some SVCD's to VCD headers since my brothers DVD player wont play SVCD. Normally I just use simple multiplex, but it just wont read this file.. -
You need to read this;
So, I think it was 2.55 that they stopped the Mpeg 2 working with any old codec, I think TMPGEnc was blamed many times for problems cause by codec's, so now there is only 3 it supports.Note for Specification Change in TMPGEnc Plus 2.57
[] When opening MPEG file with TMPGEnc Plus
Because current version of TMPGEnc Plus does not have own MPEG-2 decoder feature, it relies on other MPEG-2 decoders installed onto Windows system through Microsoft DirectShow to read MPEG-2 file.
The new version will work with Power DVD 4 codec (I use this) , but if there are other codec's of the same type it can refuse to work.
I did forget to ask if you have tried increasing the VFAPI plug-in setting for DirectShow, I always recommend a value of 4
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 15:10 -
How to Put Specifical Signs Using Credit Roll, from Sony Vegas?
By devilcoelhodog in forum EditingReplies: 9Last Post: 9th Nov 2009, 16:26 -
Switching TWC-NYC channels with a 'cable eye'
By xmiinc in forum Newbie / General discussionsReplies: 2Last Post: 28th Jun 2009, 16:02 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 10:41 -
President Signs Law Creating Copyright Czar
By drjtech in forum Latest Video NewsReplies: 33Last Post: 3rd Nov 2008, 09:57
