when i dvd2avi a movie and the files says that saved count AC3 T01 3_2ch 448Kbps DELAY -66ms.ac3 what does -66ms mean when i use dvdmistro to authorize it
thanks for any help
Find and d/l this program "AC3 Delay Corrector". When you load the delayed AC3 file into this program, it will automatically extract the delay setting from the filename (so dont rename it!) and it will fix the delay so your audio wont be out of synch in your DVD Maestro project.
Correct AR(aspect ratio) on dvd2avi conversion (16:9 vs 1.85:1)
By Visual-Artist27 in forum DVD RippingReplies: 10Last Post: 20th Aug 2010, 00:11 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 14:24 -
DVD2AVI/DGIndex Aspect Ratio Problem (Long/Stretched Faces, etc)
By munkeyman in forum DVD RippingReplies: 7Last Post: 19th Feb 2010, 10:47 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 23:43 -
How to frameserve (dvd2avi / VirtualDub / Avisynth / VFAPI)
By Truman in forum User guidesReplies: 32Last Post: 20th Nov 2007, 09:38
