hey guys i just found a box in the garage with a bunch of 650 mb cdr's. most of my SVCD's are around 750-800 mb. is there anyway to encode them and make them under 750 mb without huge quality loss?
To re-encode from the file, you already loss some quality. But this is a doable thing. You can lower bit rate when re-encode or use same bitrate but use 2 Pass-VBR instead. This will result of smaller file size and a bit of quality loss.
thanks man, but what would be a good cbr? 1600? 1700? also should i make it 352x480 instead?
Yes you can use 352x480 as well, with this resolution you will not get a smaller filesize but you will have a better quality with smaller bitrate.
I am not sure what bitrate for you original source, and I can't tell what is a good CBR setting. If you want to decrease filesize from 800MB to 740MB I don't think you have to decrease bitrate that much. I would suggest decrease about 200-300 bitrate (if original was CBR 2520 you can try CBR 2200-2300 or you can try 2pass VBR avg 2200 max 2520)
Note: if you re-encode your mpeg2 (SVCD) I would suggest you frameserve from dvd2avi. I have tested re-encoding directly from TMPGEnc but quality wan't that good. -
But why?
800mb CDRs are free after mail-in rebate or maybe 5cents each.
http://www.compusa.com/products/product_info.asp?product_code=292246
Use the 650mb for regular file back up or donate them. -
This is WHY
hey guys i just found a box in the garage with a bunch of 650 mb cdr's -
I still do not know why.
So he found $10 worth of free 650mb CDR, so now he have to spend
100 PC hours converting his 800mb svcd(s)?
Just the electric bill for the 100pc hours is probably around $10.
Use the "found" 650mb cdr for data/mp3, donate them to friends.
Problem with LG LRA-750
By polus in forum DVD & Blu-ray RecordersReplies: 0Last Post: 31st Mar 2009, 17:46 -
Hack for LG LD 750???
By sunnjack in forum Newbie / General discussionsReplies: 1Last Post: 14th Jan 2009, 14:51 -
Philips DCP 750
By tesiah in forum DVD & Blu-ray PlayersReplies: 5Last Post: 18th Jun 2008, 17:11 -
Make SVCD from prepared directory
By Gimballon in forum Authoring (VCD/SVCD)Replies: 2Last Post: 18th Jun 2008, 08:35 -
How to make a VCD/SVCD with CD Audio (CDDA)
By Baldrick in forum User guidesReplies: 74Last Post: 24th Dec 2007, 19:37
