I'm trying to encode a divX (Hannibal) movie to MPEG, to burn as a VCD. But, the first half is 700 megs. And the second is around the same, what would i do to convert these to MPEG?
Use a bit-rate calculator to find the bit-rate you need. Then encode after that. The guides on the left will help.
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 18:28 -
Dr. DivX output subtitles are big and blurry
By louv68 in forum SubtitleReplies: 2Last Post: 22nd Apr 2008, 13:36 -
Big blocks on XVid to MPEG conversion
By hewsongs in forum Video ConversionReplies: 7Last Post: 30th Mar 2008, 15:50 -
No sound when converting muxed mpeg-1 file to AVI DivX!
By mute82 in forum ffmpegX general discussionReplies: 5Last Post: 25th Oct 2007, 12:56 -
question about how to use cue file to break big audio file into tracks
By jimdagys in forum AudioReplies: 13Last Post: 12th Oct 2007, 08:40
