I'm new to DVD ripping and making SVCD and the first movie I tried to rip took me over 40 hours on my:
AMD 1.0 ghz t-bird
256 mb sdram
40gig hd
8x dvd rom
Anyways I am planning to upgrade soon so the ripping wont take so long.. I'm thinking about upgrading to at least an AMD XP 2100+ (1.73 GHz) and I'll wait untill the new KT 400 mobos and DDR 400 is available.
So if I do upgrade to this how long should I expect a movie to be ripped and converted to SVCD? Or does anyone recommend me getting an even faster cpu?
Also do duel processors make a significant difference in quality or speed of converting/encoding ?
Ripping speed is not dependent on CPU speed. Your 8x DVD is a real bottleneck. Get a 16x DVD and make sure that DMA is activated on the DVD and on your HD.
Hi wulf109, I think Warsong meant to say the whole process of ripping encodeing which took him/her 40 hours to be finished.
Then I would say CPU is the most important part of encoding process. You are right about 8x DVD and DMA, but ripping process would take at most a couple hours not 40 hours even you use only 2x DVD-rom with DMA disable.
To Warsong with your system right now, I would say 40 hours is too long. I believe that your setting is another major part of this process such as.
1) 2 or more Pass VBR will take at least twice longer than CBR. Avg with 1 GHz I would say, it will take around 5-6 hours if you encode with CBR setting on 1 hour movie.
2) Motion Serch - Highest will also take more time than other and you might not see a different in quality if you encode with " High (slow)"
3) Encoding to mpeg2(SVCD) take longer when compare with mpeg1.(VCD)
4) If you apply any filters, it will also take longer.
NOTE: all this setting I mention when you encoding with TMPGEnc
To be conclude with your system right now, I would say you can decrease the time to be around 12-14 hours per 1 movie if you can compromise all the setting.
My system is 1.7 GHz and it takes 5-6 hours per 1 movie (rip and encode).
Multiple questions on DVD Ripping / Format / Codecs
By mediafan26 in forum DVD RippingReplies: 5Last Post: 14th Apr 2012, 18:17 -
Ripping with MakeMKV and some questions
By Choque in forum Blu-ray RippingReplies: 1Last Post: 11th May 2011, 12:44 -
DVD ripping on Mac - Couple of questions
By Anonymous70 in forum MacReplies: 7Last Post: 10th Jan 2009, 06:19 -
help me with some bluray ripping/authoring questions
By ronorkis in forum Newbie / General discussionsReplies: 0Last Post: 10th Dec 2008, 21:07 -
questions on ripping software
By Mort439 in forum DVD RippingReplies: 3Last Post: 2nd Dec 2007, 22:09
