I wanted to convert the animatrix trailer onto vcd to show my friends so i tried TMpgencode but i got no audio so i tried the "mov to avi" conversion but it said no audio so i read up on the FAQ page and it talked about Audio Protect on some movies so use "Total Recorder" and then put it back together as a mpeg but the problem is after i install "Total Recorder" all the movies i play on quicktime the audio is all choppy so is there any way to fix that problem or another way to converting the .mov file.
mov 2 avi
demux in vdub
add files seperately in encoder -
i got the traailer from here.
http://www.trailersworld.com/movie.asp?movie_id=1779 -
Thx.... but can you give me a little more info on how to export the movie into a wav using quicktime.
open animatrix in quicktime pro
under the file tab, select export
the picture above will show
click the export and scroll down to "sound to wave"
save it -
if you don,t have quicktime pro, use eo video-
http://www.eo-video.com/
it works well also
All I Get is the Commercial Trailer...
By w6rlf in forum Video Streaming DownloadingReplies: 2Last Post: 15th Apr 2010, 19:31 -
Authoring with chapters and trailer
By gillmacca in forum Authoring (DVD)Replies: 9Last Post: 13th May 2008, 10:03 -
VCD to MOV - no audio on FCP
By kj1983 in forum MacReplies: 3Last Post: 9th Jan 2008, 10:05 -
New Speed Racer Trailer
By Bodyslide in forum Off topicReplies: 5Last Post: 7th Dec 2007, 23:56 -
Pirate of the Carribean Trailer
By rsgars in forum Newbie / General discussionsReplies: 2Last Post: 26th Jul 2007, 12:23
