Results 1 to 11 of 11
  1. I am trying to rip a Dragonball Z DVD. CloneDVDXp does not work at all. I then tryed Smartripper. That worked only for the one episode. I guess my question is how do you rip all the episodes??? If anyone can help me out I sure would appreciate it a lot.
    Jul 2002
    BATON ROUGE, LA - U.S.A.
    glad to help a fellow dbz fan.
    smartripper do this-
    http://mpucoder.kewlhair.com/Derrow/smartrip.html
    dvddecrypter do this-
    http://mpucoder.kewlhair.com/Derrow/ddecrypt.html
    you can also read the main page for more options on what to do with your rip-
  3. Thanks a lot man, I appreciate it.
  4. For the eps that can't be rip, just play it using your PC's dvd player to play that chapter for a second. Then go back to smartripper and it'll rip.
  5. From memory, some of the DBZ episodes have the separate episodes as separate VOBSets.
    I strongly recommend that you use DVD Decrypter and simply rip the entire disc. Then you can easily sort it through later.
    Regards.
    Michael Tam
    w: Morsels of Evidence
  6. The problem was in the process of ripping entire DVD to HD. Yes, each episode were on a different VOB. That's why there were problem.
  7. If you use DVD Decrypter or SmartRipper in "File Mode", it will be much easier to sort out.
    Regards.
    Michael Tam
  8. i am also trying to rip DBZ episodes. does anyone have any suggestions of what method to use to condense all the episodes onto as few dvd-r's as possible. i would like to be able to watch both the english dub version and the japanese w/ english subs.
  9. for ripping/compressing, you might also want to look at something like DVDShrink or DVD2One. those tools might be beneficial as well.
  10. can those programs take multiple dvds and combine them into 1 single dvd? Also, if anyone can offer a suggestion, what is a good bitrate for dbz or any other cartoon. i know most dvd's use around 8000 kbps but that is for live action stuff. i read somewhere that cartoons can be downsampled considerably without loosing much quality. sorry for the newbie questions, i would just experiment myself but my computer is kind of old and it takes forever to do all that compression. i am also open to converting the DBZ dvd's to divx or any other format that would allow me to put the maximum amount of episodes per DVDr. however, i would like to have the option to watch both the dubbed and subbed versions. i dont know if that can be done with any other formats other than dvd
  11. I am also interested in encoding anime. Do you guys have any preferences on a codec to use? Or any links to guides specifically for anime? Thanks.
