  1. i applied the patch and still get some sync problem at the end of the movies .......... also in certain movies i add scence in.... it will add jst a certain number then it wont let me add no more...... no error message or anything just stop adding it
  2. Same Here, asked for my money back!!!
  3. so is anyone else havin this problem and might can help....... maybe another easy software to use like moviefactory
    May 2002
    MONTREAL - CANADA
    I did have this probleme and everything work now.
    1)Purge the temp files in c:\windows\temp
    2)Uninstall DVDMF from control panel Add/Remove programs
    3)Reinstall DVDMF again
    4)Download the latest patchs (CD/DVD Burning Patch) from this web page
    http://www.ulead.com/tech/dmf/dmf_ftp.htm
    5)Please make sure the original video is ok.
