  1. OK i tried hard not to ask this question but I can't seem to find an answer ( Although I'm sure I've read the question before )
    I have a Divx movie where the sound is out of sync. I wanna demux it and try to fix the sync.
    How am I gonna do it ?
    Anyone ?
    thx.
    Mar 2002
    Strange as it might seem, I've had success merely 'Direct Stream Copying' avi files in Virtual dub, and most of the time (for a reason I cannot figure) the resulting file is perfectly in synch.
    Method: Load Virtualdub then File > Open Video File. Video > Direct Stream Copy. Audio > Direct Stream Copy. File > Save AVI.
    It's worked a good 80% of the time with movies badly out of synch. Worth a try if you're in a hurry.
    Hope this has been some help.
    Frankanger
  3. Thanx for the replies..... but I'm on a Mac.
    Can it be done ?
    Anyone ?
  4. first off its not multiplexed , its 2 seperate tracks. As for fixing the audio try using Divx doctor II , and then if that doesn't work try using Divx tool
    to export the audio track(as long as it isn't WMA) I have found it is easiest
    for me just to do it under Virtual PC then paste in the doctored mp3 track or just convert the entire Divx to Mpeg-1.
  5. Use QT Mutator to sync your DivX movie.
