In IfoEdit....
From my understanding of it, the chapters are stored in the IFO file and point to an area (sector) of the disc. If anything is altered (ie. audio stream stripped, video re-encoded) then the DVD files will be at the wrong sector and the DVD player gets confused.Step 3: Final sector adjustments
To make the disc work on your standalone you must load any of the IFO files that are to be on your final disc, then press Get VTS sectors. This will adjust all IFO files and overwrite the old ones with the adjusted ones.
I might be half right (if right at all!) but i'm just a novice.
how to RIP/COPY dvd with bad sector??
By ysfm in forum DVD RippingReplies: 5Last Post: 25th Feb 2011, 01:00 -
Start sector question in GEAR PRO
By sdsumike619 in forum Authoring (DVD)Replies: 0Last Post: 22nd Nov 2009, 15:23 -
Joining vobs without VTS and then getting VTS in the end?
By BurnBabyBurn in forum EditingReplies: 7Last Post: 23rd May 2008, 12:28 -
question about where bad hard drive disk sector info is stored
By jimdagys in forum ComputerReplies: 1Last Post: 20th Apr 2008, 17:24 -
How to avoid data burn to bad sector of CD/DVD RW ?
By kclgad in forum MediaReplies: 1Last Post: 31st May 2007, 08:17
