hi i put this in this topic because the action im tryin to do- burn with nero 5.5. > i was copying a dvd r with nero about 15 mins in it says isufficient space on my c disk, now i have to discs c and d respectively and my c disk is a 20 gig i store program and temporary etc. i keep about 8 gigs free but now it says fullim looking all over my files to try and find what is so friggin huge but i cant find it!!!?? all my files show that they are of normal siz????? how do i look through this disk more thouroughly to free up space and does this soud like a virus? my specs are above im win xp with a sony vaio that churns out discs usually easy
Rebooting helps, certian files (such as the swap file) stick around and consume space until you shutdown and reboot. If you normally have 8 GB free, the most likely causes of lack are space are CD or DVD images (several hundred megs a peice for the smallest), and if you've been editing alot of video, your swap file (a file windows uses as virtual memory) may have ballooned to several hundred megs.
i understand that but i cant find the file to delete or move anyway to find where the big file is? yes ive checked the accessible folders
In all likely hood its not one big file, but several medium sized files. I recently had to do some file cleaning myself, and was trying to figure out how 2 GB got eaten. I found out that it wasn't any single thing, but 40-50 MB each for games, I had 40MB of downloaded things in my Mirc directory. 40 to 50 megs adds up after awhile.
You might try looking on www.download.com for a program that shows graphically the layout of your folders, and how much is taken up by each. -
i found out that i was trying to copy a dvd-r and nero started copying it to a cache on my c drive well it ran out of apace and a window came up saying not enough space so i shut down nero and went searching for the big file..... well it turns out that even though i had shut down nero it left the incomplete copy in a temporary cache in my c drive that i finally found.. now i use d.
a new question is why when im copying a 4 gig dvd-r does it take up 9 gigs on my computer in a temporary file?
Burnin DVD via Flick, all DVD clips come out pixilated towards end of disc?
By jacknscoob in forum Authoring (DVD)Replies: 27Last Post: 28th Jan 2012, 06:48 -
sony DVD Recorder RDR-GX257 "unknown disc "msg
By corpjet in forum DVD & Blu-ray RecordersReplies: 2Last Post: 16th Feb 2010, 12:08 -
DVP5982/37 "unknown disc"
By Alexo in forum DVD & Blu-ray PlayersReplies: 17Last Post: 13th Mar 2009, 14:36 -
Unknown Disc on Tevion Model no TCHT 2000
By Brimac in forum Newbie / General discussionsReplies: 5Last Post: 1st Jan 2008, 11:39 -
"Unknown Disc" error for all DVDs - is my player dead?
By RosieP in forum DVD & Blu-ray PlayersReplies: 6Last Post: 8th Nov 2007, 07:49
