No picture. I bought the card last night and installed without much problem. I have downloaded the latest drivers and tried both cable and conventional antenna. It acts like I am receiving a signal, but no picture. It is not sharing an IRQ & everything appears to be OK. I'm probably going to try some capturing today...but looking for some advice.
Thanks, Samcut
Results 1 to 13 of 13
Are you getting audio?
There might be some preview/overlay problems if the card is detecting the TV channel and gives audio. If there is no audio or video, then the card is most likly not installed correctly. Try reinstalling the drivers over again (manually). WinTV2000 is the viewing and capture application that should work with the card. -
Also try hitting the Record button see it will record any if so what happing?.
Treid pulling my firewire card out and installing in PCI 2. PCI 1 is to close to the fan on my Video card. Also, uninstalled everything, and reinstalled. No luck. Tried recording, and it acted like it was recording, but of course it was just black. Tried to play recording and it gave me the following:
Connecting videorender without snapshot filter
No combination of intermediate filters could be found to make the connection.
IRQ
IRQ 0 System timer OK
IRQ 1 Easy Internet Keyboard OK
IRQ 3 Communications Port (COM2) OK
IRQ 4 Communications Port (COM1) OK
IRQ 6 Standard floppy disk controller OK
IRQ 8 System CMOS/real time clock OK
IRQ 9 VIA Rev 5 or later USB Universal Host Controller OK
IRQ 9 Creative AudioPCI (ES1370), SB PCI 64/128 (WDM) OK
IRQ 10 Hauppauge WinTV-PVR PCI II (Encoder) OK
IRQ 11 NVIDIA GeForce DDR OK
IRQ 11 3Com 3C905TX-based Ethernet Adapter (Generic) #2 OK
IRQ 12 Logitech-compatible Mouse PS/2 OK
IRQ 13 Numeric data processor OK
IRQ 14 Primary IDE Channel OK
IRQ 15 Secondary IDE Channel OK
AGP
PCI 1-nothing
PCI 2-PVR-250
PCI 3-Nothing
PCI 4-Soundcard
PCI 5-Network card
Please help-
Thanks, Samcut -
samcut record 3sec clip and sent to so I can review it, sent to shspvr@shspvr.com
Got it! Changed my monitor from default to plug & play and it works. I will now move onto capturing video via svideo from my Sont TRV120.
Thanks to all,
Samcut -
OK, not quite ready to write my review yet. The tuner function works great since I changed my monitor type. Now I'm on to my next challenge and have not found the answer yet. I connected my camcorder up to the PVR-250 via Svideo. It records and plays back great in WinTV. However, playback sucks in Win media player. But both are playing no sound? I played with the settings and still have had no luck. I should just need to hook the Svideo up correct? Help would be appreciated.
Samcut -
Downloading and resinstalling the Windows Media Player usually fixes all problems with the media player.
As for audio, there are only one set of inputs, both comon for composite and S-video input. Simply plug in the a small audio jack (like the ones used on stereo headphones for a walkman) and connect the other end to the RCA audio outputs on your VCR or other video output device. There is an audio adjustment in the registry you can adjust for the correct audio levels. Do you get audio from the tuner? I would assume so, that leaves the audio cables between your VCR and the inputs connector on the PVR-250.
http://steve.kittelsen.com/pvr250 -
Yup I have agree with skittelsen it dose sound like you forgot hook up the audio cable from your camcorder to the PVR 250.
Note about min camcorder they do only mono sound so you need get a mono to stereo jack. -
Thanks guys. I kept reading my camcorder manual and the PVR forum notes, and it kept mentioning just the Svideo...no audio cable. Seems to only make sense. I'll pick up a cable a radio crack and give it a try.
Thanks, Samcut -
Well I did, thanks for all the help. This card wors great. See my review under capture cards. I would recommend to anyone.
Samcut
Hauppauge WinTV-PVR 250
By thatsgame1 in forum Newbie / General discussionsReplies: 5Last Post: 22nd Jun 2011, 07:54 -
Hauppauge PVR-250 software question
By Ogilvy in forum Capturing and VCRReplies: 19Last Post: 28th Sep 2010, 03:11 -
Hauppauge WinTV PVR 250
By kenmo in forum ComputerReplies: 10Last Post: 28th Apr 2009, 14:21 -
new pc and my hauppauge pvr 250
By heman28 in forum Media Center PC / MediaCentersReplies: 1Last Post: 27th Jan 2008, 08:33 -
Want to replace Hauppauge pvr 250, what should I get?
By heman28 in forum Capturing and VCRReplies: 9Last Post: 25th Jan 2008, 09:25
