Hi, Ive no problem converting the main movie files from a DVD via CCe or TMPENG but when it comes to the extras eg deleted scenes they seem to be interlaced and dont play right , any suggestions on this?
You didn't specify if you were converting to MPEG1(VCD) or MPEG2 (SVCD). If you're converting to SVCD the best way to handle interlaced material is to encode to interlace instead of progressive. This only works if you're "NOT" changing framerates because the interlace structure of the source can be matched. If you're making a VCD you're going to have to turn on some sort of "de-interlace" filter since MPEG1 doesn't support interlace frame type.
-LeeBear
Can an interlaced file appear not to be interlaced on the monitor?
By rcavanah in forum Authoring (DVD)Replies: 5Last Post: 10th Sep 2011, 22:09 -
Converting DV to H.264 and comparing interlaced/de-interlaced
By amirh1 in forum Video ConversionReplies: 5Last Post: 23rd Jun 2010, 09:16 -
Deleting Extras with BD Rebuilder
By wulf109 in forum Blu-ray RippingReplies: 0Last Post: 27th Dec 2009, 23:10 -
Strip Extras?
By Cabal2000 in forum Blu-ray RippingReplies: 1Last Post: 6th Mar 2009, 06:51 -
Convert interlaced HD to interlaced SD with AVISynth
By jorbje in forum Video ConversionReplies: 19Last Post: 22nd Mar 2008, 18:48
