Ok ... I'm really new to this. I have created my first Video CD using Virtual Dub, TMPGEnc, and Nero to burn the CD, just as the manual says.
... However when I place the CD in my PC DVD reader it does not autoplay. I have to manually go and look for the DAT file and open it. Is there a way that will allow autoplay as soon as I place the CD in my PC DVD player ?
Anrasp
include a player and an autorun.inf , but Windows Media player could be told to play the file (As above)Originally Posted by Anrasp
If you dont have one, drop me an email -
: ( Well the autoplay did'nt work
I copied the nfo file in the root directory
with the following text inside
[autorun]
open=start mplayer2.exe /play /close \MPEGAV\avseq01.dat
Is it because the my Media player target file is this wmplayer.exe instead ? If in the affirmative, my nfo file should contain
[autorun]
open=start wmplayer.exe /play /close \MPEGAV\avseq01.dat
Can someone confirm please ?
Anrasp -
Panasonic DMR-ES45VS, keep those discs a burnin'
Originally Posted by AnraspIf you double click the .dat does it play in media player ? is it associated with .dat file to play them ? Else it might not open in anything or the notepadOriginally Posted by Anrasp
This is why people add players... Ill send you one !!
JVC SR-DVM70 160GB part of the HDD image needed
By dvd4met in forum DVD & Blu-ray RecordersReplies: 4Last Post: 2nd Feb 2013, 20:11 -
Possible to convert ONLY audio part of WMV, but not the video part?
By tigerb in forum Newbie / General discussionsReplies: 2Last Post: 27th Jun 2011, 19:57 -
how can i edit a small part inside a movie and make that part look bigger?
By xxquatroxx in forum EditingReplies: 1Last Post: 24th May 2010, 16:32 -
TMPGEnc cannot open the video part of the file, only the audio part can.
By dzsoul in forum Authoring (DVD)Replies: 15Last Post: 3rd Apr 2009, 09:36 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 19:30
