I HAVE RIPPED THE DVD WIT OSEX, ENCODED WITH MACDIVX CREATOR, CUTTED IN TWO PIECES WITH QT6 AND FINALLY ENCODED IN TOAST VCD BOTH WITH QT6 AND/OR TOAST BUT THE RESULT IS ALWAYS THE SAME AFTER 6 MINUTES IT GOES OUT OF SYNC THE VIDEO IS SLOWER THAN THE AUDIO. ANY SUGGESTION?
I HAVE CHANGED THE FRAME RATE TO 25 (AS FO PAL) BUT NO WAY AND SVAED AGAIN THE FILE IN .MOV
AS USUALLY AFTER 5/6 THE MPEG1 STARTS TO GO GRADUALLY OUT OF SYNC
THE MOV FILE WHICH I USE AS A SOURCE TO CREATE THE MPEG1 FILE HAS NO PROBLEM OF SYNCHING THE PROBLEM COMES OUT WHEN I ENCODE IT IN MPEG1. HOWEVER, THE FIRST 1/6 OF THE MPEG1 FILE IS IN SYNC, AFTER THIS POIN IT SLOWLY STARTS TO GO OUT OF SYNC AND THE END IT'S A MESS
I USE QT6 ON AN IBOOK 600MHZ WITH MACOS X.1.5 AND 256MB OF RAM
Results 1 to 1 of 1
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
Videos in sync on pc, out of sync on DVD player
By DVantrease in forum Video ConversionReplies: 3Last Post: 2nd Sep 2009, 04:08 -
MPG with A/V sync to AVI with horrible A/V sync?
By RedPenguin in forum Video ConversionReplies: 92Last Post: 23rd Aug 2009, 16:17 -
VCD to PSP - Audio out of sync in last five minutes
By BozQ in forum Video ConversionReplies: 6Last Post: 2nd Apr 2009, 22:43 -
VCD audio out of sync on player
By burnerbie in forum Authoring (VCD/SVCD)Replies: 2Last Post: 10th Aug 2007, 12:15
