How can i join 2 Divx AC3 sound together?
ok i say that in a difrent way...
How can i join 2 Divx movies (part1+2) with AC3 sound to 1 part with AC3 sound? -
I your having problems with the "append", try Vdub AC3
http://www.digital-digest.com/dvd/downloads/virtualdub.html
If necessary save out he audio as uncompressed, then join them back later >Audio > WAV -
Thanks...
Do you know how can i "rip" AC3 from Divx movie?
and how can i join 2 subtitles?
i want to re-encode the Divx to DVD and burn it like a DVD...
I have the richo dvd burner... -
it sounds lke you want to put 2 divx on 1 dvd ... i think ...
dont try to join anything togther is my suggestion .. just follow the guides on the left for converting divx to mpeg2 .... dvd standard ...
and author each seperate onto a dvd ..
if you dont use perm. subtitles - you will need an authoring program that can take subtitles ... -
No, its 1 moviw spilt to 2 parts....
i already join them together with AC3 now i want to join the subtitles together and re-encode to DVD using Canapus Procoder (Grate app!!)
that way i will have mpeg2 with subtitles....i think...hehe...
you have any ide..? -
Two methods, one may only work for youOriginally Posted by wizzy
Audio > direct stream copy
SAVE WAV
You have now saved the AC3 as a WAV, rename to AC3 to convert it to WAV with "headac3he"
Next method, and one that I use all the time
Audio > Full processing mode
Audio > conversion > 44.1Khz
SAVE WAV
You now saved it out as an uncompressed WAV at 44.1Khz
SubStation Alpha ?? for subs
Join AC3 files
By rgraiche in forum AudioReplies: 8Last Post: 20th Aug 2011, 16:56 -
How Do I Join M2V and AC3 Files?
By lovelylisa in forum Video ConversionReplies: 1Last Post: 6th Jun 2011, 18:13 -
How to join ac3 files?
By X_Splinter in forum AudioReplies: 9Last Post: 30th May 2010, 10:10 -
no sound on dr. divx ac3
By jwdove in forum DVD RippingReplies: 1Last Post: 25th Jun 2008, 05:07 -
LOAD CLICK AND LOW SOUND at join of 2 avi xvid ac3 using vitualdub
By hawklight in forum EditingReplies: 0Last Post: 15th Jul 2007, 09:44
