I have a 20 fps avi and would like to convert it to 23.97 NTSC vcd, how do I do this without losing sync with the sound?
Any help would be appreciated, Thanks.
Changing frame rate is never simple. But TMPG seems to handle it well. I don't know how exactly TMPG converts frame rate, but it gets job done. Keeping synch while changing frame rate, things just don't go any easier
I can't be very specific here, just some advice:
A. Encode video and audio separately, then mux them together.
B. If there is synch problem, try different A/V offsets.. or you may need to stretch or shorten audio to keep synch with video.
Issues Converting from 25 fps to 29.97 fps
By Klagar in forum Video ConversionReplies: 7Last Post: 13th Jul 2011, 12:30 -
Changing AVI Properties (Resolution, FPS etc) NTSC>PAL
By skywalka in forum Video ConversionReplies: 4Last Post: 7th Mar 2011, 21:45 -
Converting 23.976 fps to 29.97 fps
By wasimismail in forum Video ConversionReplies: 8Last Post: 14th May 2008, 19:26 -
Converting 23.976 fps to 29.9 fps
By zanos in forum Video ConversionReplies: 4Last Post: 13th Apr 2008, 10:03 -
30 fps flv to 25 fps avi or vcd
By cd090580 in forum Video ConversionReplies: 5Last Post: 12th Nov 2007, 09:35
