No sound on a Divx I was given. The audio is encoded at 192 but appears to not be mp3. Picture is perfect however. Any ideas?
If you load your video into Gold Wave, it will show if there is any audio in your video. If there is audio, you can amplify it, or mix it into both audio channels to make sure it works.
Hello. -
Load the AVI into Vdub, select file > file informationOriginally Posted by ridgewood
This will tell you what codec was used, if its shown as unknown, then you have a missing codec. It may be AC3, install Nimo lite
additional audio decoder needed to play this soundtrack-Dolby AC3 Audio
By tbone1209 in forum AudioReplies: 6Last Post: 19th Jun 2011, 20:58 -
Will Sony Vegas work with a high end audio interface used for digital audio
By fuzzblaster in forum AudioReplies: 3Last Post: 1st Sep 2010, 17:24 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 01:29 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 04:12 -
demux audio from avi then two audio sources(aac 2ch + ac3 6ch)
By fatcat23 in forum ffmpegX general discussionReplies: 4Last Post: 21st Sep 2008, 01:19
