i have a 500 mb mpg file which i want to share over the net. How can I reduce the filesize to around 200-250 mb without too muh quality loss in avi format.
You can use either DVD2AVI or VirtualDub to convert an MPEG to AVI.
I would suggest you use DIVX codec for the conversion - you can experiment with the DIVX settings to get the size/quality that you want. -
VdubOriginally Posted by mk15
Video > full processing mode
Video > compression > codec > DivX low motion > 500 bitrate
Audio > full processing mode
Audio > compression > codec > MP3/DivX > 128 ? bitrate
SAVE AVI
Try other lower values -
I am attempting to do the same thing, but when I try to use VirtualDub, nothing happens.
I hit F7 to save avi, and it look like it is trying. The status window's time elapsed field is counting, but noting else changes. It is just sitting there.
Any ideas?
rod. -
On all codecs ? or just some ?Originally Posted by jenkins
Is the origial AVI tested for junk frames ?
Help converting small size but large stream size asf video stream file?
By apple4red in forum Video Streaming DownloadingReplies: 5Last Post: 11th Oct 2010, 12:01 -
Is there an easy way to determine the frame size of videos?(avi, mpg, etc)
By True Colors in forum Newbie / General discussionsReplies: 2Last Post: 17th Apr 2010, 16:45 -
small video size, but showing incorrect size (too big)
By mandy in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2009, 05:14 -
Mpg to fixed avi size.
By jjulio1 in forum Video ConversionReplies: 12Last Post: 8th Mar 2008, 15:59 -
File size problem with TMPGEnc [.avi to .mpg conversion]
By Timex in forum Video ConversionReplies: 7Last Post: 26th Jun 2007, 22:50
