I am not sure whether to use Interlace or Non interlace Progressive?
What is it? And how do you know which one to use?
The guides do not describe it well or tell you which to choose?
Thanks for helping me with this simple question.
Spanishfly
As I understand it, interlacing is how the image is written to the screen. As an example, if the screen is made up of 100 horizontal lines the interlaced image will fill the screen from top starting at line one and filling line 3, 5, 7 etc, this is the first pass at displaying the image, a second pass is then perfomed which fills lines 2, 4, 6, 8 etc until the whole screen is filled with the complete image. I use TMPGenc to encode and use interlacing from bottom field up.
You're just a tube full of gas and a box full of tin, you show me your charms and I want to come in. -
So, what is the difference between interlace and non-interlace?
How will the image look different if I use non-interlace?
What is better?
How do you know which to use?
Spanishfly
interlace help
By nymph4444 in forum Newbie / General discussionsReplies: 339Last Post: 17th Jun 2011, 02:33 -
Interlace or Bitrate ??
By garylanders in forum Authoring (DVD)Replies: 14Last Post: 4th Jan 2011, 05:14 -
By garylanders in forum Authoring (DVD)Replies: 1Last Post: 29th Dec 2010, 13:43 -
Question about HD to SD and interlace>progressive>interlace
By ayim in forum Video ConversionReplies: 4Last Post: 10th Dec 2009, 12:21 -
Interlace Question (I think....)
By pezpunk in forum Newbie / General discussionsReplies: 4Last Post: 15th May 2008, 10:20
