Hi
Gday
ive being using tmpgenc for sometime now.
Ive downloaded Atlantis the lost city.
I thhink it was ripped from a dvd and into an avi.
Ive split the file..but when i try to encode the file it keeps quitting because it claims something about a illegal floating point decimal order.
What is this all about and can i fix it?
thanks!
Matthew
Please read the Newbie Guides hereIf TMPGEnc freezes or crashes when converting or you receive errors such as
Unexpected decimal point calculation
Illegal floating decimal point calculation order
Try first to change the codec reader settings in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the DirectShow Multimedia File Reader and increase the priority to 1 or 2 and try open the video.
Or try to convert the audio to wav before converting.
Or try to repair the AVI,DivX or the ASF.
Or try to use avidefreezer to fix your video source.Hello. -
Download "vdub-mp3-freeze.exe" or try and use the Vdub you already have.Originally Posted by MattGoodyear
http://www.digital-digest.com/dvd/downloads/virtualdub.html
Scan video for junk frames, if it finds any
Video > direct stream copy
Audio > direct stream copy
SAVE AVI
This will save the AVI without the junk frames, that causes TMPGEnc to crash.
vdub-mp3-freeze, does the same think but is more reliable, it makes a log of the junk frames at c:\junkframe.log which can be used to delete the junk frames (At keyframes) starting at the highest blocks first.
Help - invalid Floating point operation!!!!
By Pintocas in forum AudioReplies: 1Last Post: 15th Sep 2010, 10:28 -
Convert DVD9 layer break to decimal format on Eclipse report?
By sdsumike619 in forum Authoring (DVD)Replies: 4Last Post: 31st Aug 2010, 19:41 -
r6002 floating point error with MPC , maybe
By BWMagus in forum Software PlayingReplies: 5Last Post: 19th Mar 2009, 09:08 -
MPC Runtime Error, 6002 floating point support not loaded.
By Leo99 in forum Software PlayingReplies: 5Last Post: 24th Nov 2008, 03:22 -
Point to point sharing with wifi adapter and wifi router?
By yoda313 in forum ComputerReplies: 5Last Post: 17th Jul 2008, 18:47
