hi, I cannot seem to cut my mpegs with tmpgenc`s merge/cut tool anymore.
When I load the mpeg I cannot move the slider bar to set the cut position anymore, It used to work.![]()
I am in XP pro and if I boot to win98 and use the same prog it works...
Any help would be greatly received as I don`t want to keep going into Win98 to edit.
Thanks all.![]()
For what it's worth, I had this same problem recently - I tracked it down to a conflict between TMPGEnc and WINDVD, some how they had 'tripped' each other up preventing TMPGEnc from doing MPEG playback. I just uninstalled and re-installed WinDVD and the conflict was removed - both now work fine.
May be of some help.
Problems Cutting MPEG video in VIRTUALDUB
By Rudyard in forum EditingReplies: 2Last Post: 30th Sep 2010, 21:25 -
Problems when I try to add subtles in my video on TMPG DVD Author 3
By ihmcjacky in forum Authoring (DVD)Replies: 4Last Post: 22nd Mar 2008, 01:24 -
cutting an MPEG
By php111 in forum EditingReplies: 3Last Post: 7th Jan 2008, 08:32 -
WMV cutting-joining-playback problems
By Cusem in forum EditingReplies: 2Last Post: 7th Dec 2007, 03:48 -
Convert mpeg-2 to xvid while cutting commercials...
By swishbish33 in forum Video ConversionReplies: 5Last Post: 25th Oct 2007, 18:10
